waqas5304 said:hi
i want to convert 24 V dc to 50 V dc , any idea to do it
Could be a lot more. Without a load, the voltage will rise until either transistor or diode reach avalanche breakdown. Depending on the current level, they may possibly not withstand this operation. Thus if no pwm voltage regulation is provided, you should have at least a zener diode limiting the output voltage. Basically the part count wouldn't be higher using a SMPS controller as oscillator, e. g. they said type, but you have a precise voltage regulation then.On the collector you'll have 2..3 times the supply voltage.
