matrix keypad interfacing with PIC18F4520
isabella
Junior Member level 3
hi all,
i want to use a pic and a keypad to display a description on a lcd.
when you press a certain code the corresponding description of that code must be displayed.
the code must be 2 digits, ranging from 00 to 99.
can any one help me with a sample code for reading the 2 digit code that has been enterd into keypad.
note: after entering the 2 digit code, you must pres ''ENTER" and to erase the entry you must press "CLEAR"
also, the number you enter must be displayed on 7segments as well.
please help
which pic language re using? i can try if u donnt mind in basic.
Hi thanks for replying. I am using mplab and c language. Can anyone help? Please?
isabella, try and check outthe site posted above. i checked it out and i think its ok. one thing i found interesting is that it uses interupt on change on portb which makes it good forr u to do other things with the micro like updating ur seven segment. the res of the code is easy. what u need is maybe a look up table or a select case that will compare the code entered then see if it matches whit the one u ve pre programmed on the micro. hope this helps
thank you for all your replies. i've just been told that i am not good enough to do this project. maybe its the truth. think im going to leave this project for someone that's better.
thanks anyway guys.
