TxJoe
Newbie level 2
- Joined
- Mar 11, 2015
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Texas
- Activity points
- 16
Hi All, this is my first post.
So I'm working on my sprinkler system and I have a break in a buried wire somewhere between my control box and the solenoid valves. I'm looking to build a circuit that will either use one of my good wires and then splits the time evenly sending voltage to 2 to 4 valves or making what they call a doubler.
A doubler has two components, one on the control box side and one on the valve side. The one on the control box side is connected to two stations and then runs a signal (I'm guessing through a pulse) and voltage through one wire. The one on the valve side receives the signal and then deciphers which one of the valves to send the voltage to.
Thanks in advance!!
Thanks in advance!!
