subbuindia
Member level 5
- Joined
- Dec 13, 2011
- Messages
- 87
- Helped
- 11
- Reputation
- 22
- Reaction score
- 10
- Trophy points
- 1,288
- Location
- Vellalacheruvu(AP), India
- Activity points
- 1,908
What is the difference between variable resister and rheostat?
Rheostat is a a two-terminal variable resistor.What is the difference between variable resister and rheostat?
Well you could take a look at the posted image at post #3. Potentiometer on the left has three terminals. Staying on the rheostat part of the image (right side), you can see an arrow in the middle of the rheostat. When you change rheostat's resistance, this arrow can travel from the left (R=0) to the right (R=max). Assuming a perfect linear relation between distance and ohmic value, then the arrow in the middle means R/2.subbuindia said:but rheostat has only two terminals. Then, how can it act as varying device?
For potentiometer yes. For rheostat no, there are only two terminals. Maybe the below image could make you understand this better:Well sir......,
is it (arrow) treat as 3rd terminal?
