220 AC input to microcontroller
qpasatio
Newbie level 5
hello
Does anyone know a good and cheap solution to sense the 220V AC from a pic microcontroller?
An Optocoupler would be a good solution, but it is very expensive. I´ve read a appnote from microchip and they sense the line direct with a 20M resistance. Do you think is a good idea?
Thanks
flatulent
Advanced Member level 5
Middle Earth
You need to comply with safety regulations. I would use a transformer or the opto isolator method. Avoid all direct connections to the mains. You also have to guard against lightning strikes to the mains conductors getting into your circuit.
davorin
Advanced Member level 3
Switzerland
How do you power your PIC? Directly from AC line or through powersupply with transformer?
If it´s direct AC line then you can go with a 10/20M resistor and add external protection diodes to VCC/GND to input pin. There must be some app-notes for dimmer applications here at edaboard...
If your powering from transfor supply why don´t you feed AC signal from there?
If none of them is true then go with optocoupler...and please #define EXPENSIVE (o; When it comes to safety nothing is expensive...
Moof
Full Member level 2
Argentina
I build an controller with a 12f675. In my aplication i use 40M to the zero cross detectorf of the 220v (Argentina). It is safe cos Pic has two diode to protect the input, so Voltage never is going to be grater than 5V a less than 0V (-0.7). The 40M resistor prevents thath this diodes melt down. :D
Apart from that im not using transformer. I use two capacitors, two diodes, a zenner and a resistor.
To avoid the hight voltages i use a varistor at 450 volts peak.
cozturk
Trust me: this is only 3Mohm resistor to pic input. No 20Meg. and no diodes neded. because they are built in PIC.
I used this method to zero sensing in phase control circuit. (thermal regulated heater project)
qpasatio
Newbie level 5
Thank you for your replies
But.... I need 1 or 0. The resistante is a good method if you activate an interrupt to detect the zero cross. In order to detect Fase oder Neutral, I think that it is necessary to add diodes... condensators... and so on.
davorin
Switzerland
What you mean by "detect phase or neutral" ????
Do you wanna detect only polarity?
It already does it (o;
qpasatio
Newbie level 5
Sorry, Possibly I didn't use the correct terms. I feed a sensor with 220vac (relay inside). The relay returns 220 oder N.
davorin
Switzerland
Sorry...now I don´t really see what you want to achieve with this (o;
Always output same polarity regardless of input?
qpasatio
Newbie level 5
qpasatio
Newbie level 5
Usually engineers make difficult the most easy thing. :)
It´s very easy. I have a presence sensor with 3 terminals. These terminals are the tree connections of relay.
I use this connection:
NC (normally closed) -> N
NO (normally open) -> F
C (common) - > to the microcontroller Input (signal)
If the sensor detects presence, the signal is 220, otherwise, N.
I don´t know if my english is precise, if you don´t understand me I can send you one scheme.
davorin
Switzerland
Let´s say your english is "understandable" and a schematic would have been much better from the beginning (o;
I think you mean with "F" phase?
Now you´re talking more strange...what "presence"? What "sensor"?
The sensor should switch the relay between "N" and "P" when 220V is present and feed it to the PIC?
Please draw a block diagram (o;
cozturk
for pbp. to sync. to mains:
if pin= 1 then
while pin=1: wend
else
while pin=0: wend
endif
pause 1ms
trig. triac etc
qpasatio
Newbie level 5
Let´s try it now.
The opto is very expensive and I had some problems, maybe a good selected capacitor with the 680K resistance could improve the circuit.
thanks
cngroup
Newbie level 3
I'm also curious about this too. How about coupling with some capacitance?
Fragrance
East Of Earth
qpasatio said:
Let´s try it now.
thanks
insteed of simple opto why not you used MOC3020 or MOC3040 the 3040
come with built in zero cross and suitable for interfacing and controlling 220vac direct from Uc i have built temp controller by using moc 3040
if you need more help i will guide you more
tryagain
Newbie level 1
ref some cheap battery charger circuit
