KnowYourPlanet
Newbie level 1
Hello,
We are a small company specialising in the sales and distribution of solar cells and accessories. We are looking to increase our product range by having a series of solar power kits where you, for example, use 3 zener diodes, 3 leds, a 12 volt battery and a series of solar cells to charge + resistors etc, basically a very simple battery charge indicator. What we need is the correct wire diagrams, tables for various battery voltages and so on drawn by an expert. We would also like to further expande this range to a series of 3'rd world product lines and we have quite a few cool ideas for designs which we would like to develop.
We can provide the raw components where required and a commission paid upon completion of a specified project and prototype built/tested.
The range must be analogue, with no microprocessors, it must be made with components which have been around for a while, are readily available worldwide. Performance in regards to loss to heat is less important then durability, these systems must be designed to last, be rugged and open to repair.
If this sounds like you, how you work then send a bit about yourself to mark@knowyourplanet.com. We are based in London but applications are welcome from anywhere in the world.
Kind regards
Mark
Kind regards
Mark
