[SOLVED] 20x4 LCD interfacing with LPC2368
shashank07
Junior Member level 2
hello Friends
I am working on 20x4 lcd interfacing with LPC2368.
I already work on 16x2 lcd.
Is both display initialization same?
how to write data on different line
I mean what is line address?
does any one have experience on 20x4
ud23
Advanced Member level 3
Yep, the initialization is same as 16X2 LCD, the third line is the continuation of first line and fourth line that of second line.
first line address : 00h to 13h
second line address : 40h to 53h
third line : 14h to 27h
fourth line : 54h to 67h
shashank07
Hi Ud thanks for reply
so if i want to write data on 2nd line i'll give 40 as a command
and cursor will automatically come to 2nd line right?
nandhu015
Advanced Member level 5
India
Yes, the cursor will be on the first position
shashank07
that's nice
I have done with almost everything in coding part
but stuck at one point
my data pins are not at single port D0-D3are at port0 and D7-D4 are at port 1
now if i want to display a single character what should I do for example 'A'
nandhu015
India
that's nice
Why dont you try it in 4bit mode..
shashank07
Hi nandu
to test code I am using 16x2 lcd on LPC2148 as I have that board available
I made according changes for that.
I check that code on debugger its working as per requirement
BUT when I test it on board I found one problem
LCD enable PIN is not getting HI at the time of command
also i check data pins of LCD with oscilloscope I am getting 0x38 which is first command
but enable pin is still low
Any solution?
nandhu015
India
Hi nandu
Any solution?
I cant find out the fault unless i see the code.
shashank07
give me your mail id so that i can mail you
shashank07
Hello friends
My code is running problem was the contrast settings
So i change POT settings and its working :)
bianchi77
California
do you mean
lcd_cmd(0x14); and lcd_string("something") ?
it doesn't work...
zuisti
Advanced Member level 1
Hungary
Set the parameter's 7th bit to 1.
Use this:
lcd_cmd(0x80 + rowaddress + colnum);
eg
lcd_cmd(0x94); //0x80 + 0x14 + 0: third line, pos 0
