need pic16f677a - CAN schematic
abishekmudalur
Member level 1
coimbatore,india
need pic16f877a - CAN schematic
hi to all....
in my project,i m in need to make a CAN network.....
i m using pic16f877a.....
i planned to use mcp2515-mcp2551( CAN controller-tranceiver)
can anyone paste schematic......
Re: need pic16f877a - CAN schematic
here i enclosed my schematic....
it contain
pic16f877a
3switches in portD
3LEDs in portE
rs232 serial communication
can-spi conection
plz check & tell if anything s wrong....
I've uploaded several appnotes and sample code, one in particular has the schematic to interface a MCP2515 and PIC16F876 with example code, just modify accordingly.
This should get you started in the right direction. I take a look at your schematic later today. If you have any other question just drop me a PM
  • 00212c.pdf
  • 00212.zip
  • 00215c.pdf
  • an215bsc.zip
  • 00713a.pdf
  • 00872a.pdf
  • 51454a.pdf
  • 2515_1939_1.01.zip
hi all
In PIC 16F877 there is no inbuild support for CAN interface, u need to connect external CAN driver. it i sbetter if u use Microchip PIC18, PIC24H, dsPIC30F and dsPIC33F Microcontrollers with embedded CAN Controllers.
ur task become easier.
Ashad Mustufa
eLab Solution Provider
yea...tats k....but i m doing project using pic16f877a only.....half way crossed....still CAN only left....so i planned to use mcp2515,mcp2551 along with 16f877a.....
I think you already studied in detail about CAN protocol, it has its own memory map and addressing method. I know you already used the PIC16F877 but it is thankless job to implement all these addresses and HW feature through programming.
Again my suggestion, read the CAN Bus in detail. After that you will reveal that it is much easier to change the PCI16F877 with CAN enabled controller than implementing this feature by programming.
Ashad Mustufa
thnks sir...but i already made the PCB with all the external components with 16f877a and mcp2515,mcp2551.....so i cant change my design again....it ll take more cost since i designed 5 PCBs....cost s not a matter.....but i hv very little time only.....still only 20 more odd days to go....so i m in a deep critical stage....
Attached is a CAN example project compiled using CCS. Node B incorporates a 16F876 with a MCP2510. You should be able to modify the code to incorporate the components you have selected and your design.
This source code you start you off in the right direction.
  • CCS_CAN_EX.zip
