ADC 16f877 from 8 to 10 bit
maria258
Member level 2
I have already done an 8 bit mode adc but would like to change it to 10 bit. How can this code be altered to make it a 10 bit?
thanks
maria
#include<htc.h>
__CONFIG (0x3F72); //configured fuses
//define ports for easier reading
#define LEDS PORTB
void delay(unsigned char itime);
void main(void)
//8bit data-type variables
unsigned char x;	//ADC low byte
unsigned char y;	//ADC high byte
unsigned int z;	//final result
TRISB=0x00; //output
TRISA=0xFF;	//inputs
LEDS=0xFF;	//clear/switch off LEDS
while(1)
//ADFM=1, all i/ps analog, +VREF enabled
//Configure the functions of the Port bits
ADCON1=0b10000001;
//clock/channel select & enable bits
//controls the operation of the A/D module
ADCON0=0b11000001;
delay(1);
//Start a2d conversion
//Set GO bit (ADCON0=ADCON0|1;)
GODONE=1;
//wait end-of-conversion (conversion complete)
while(GODONE==1);
x=ADRESL; //store low byte
x=x>>1;	//shift 1 bit to the right
y=ADRESH;	//store high byte
y=y<<7;	//shift left 7 bit position
z=x|y; //combine together
LEDS=~z; //output on leds
unsigned char i,j;
for(i=0;i<itime;i++)
for(j=0;j<1;j++);
/*--- Initialise A/D convertor ---*/
void init_ad(void)
  ADCON1 = 0x20U;   /* Conversion clock Fosc/32 */
  ADCON0 = 0x80U;   /* 10 bit Right justified result, Vdd as ref */
/*--- Read A/D conversion ---*/
int read_ad(unsigned char channel)
  int result;
  unsigned char acquisition_time = 3U;
  ADCON0 = 0x01U;             /* Turn on A/D */
  ADCON0 |= (channel << 2U);  /* Select channel */
  while(acquisition_time--){ /* Sample channel */
  GODONE = 1U;    /* Start conversion */
  while(GODONE){  /* Wait for conversion end */
  result = ADRESH;
  result <<= 8U;
  result += ADRESL;
  return result;
but the problem is since it is 10 bit and they are shown on leds, there will be another 2 leds that need to be shown on another port and dont know how to do that.
thanks
#define LEDS_8 LATB
#define LEDS_2 LATC
void read_ad(unsigned char channel)
  LEDS_8 = ADRESL;
  LEDS_2 &= 0xfc;
  LEDS_2 |= ADRESH;
Hi Sir btbass,
I am new in pic and I use 16F877A ,MPLAB and Hi-tech C compiler,
I read about ADC for one month plus & try those who master in this code but does not work for me. Especially ADGO or GODONE always give me compiler error.
undefined identifier "ADGO"--
Any advice form you Sir, Thanks a lot.
---------- Post added at 04:01 ---------- Previous post was at 03:52 ----------
Sorry still not finish,
I am using sharp sensor GP2d120 and I connect to RA1 pin as analog input.
Physically I can measure the voltage when I play around with object distance.
But soft code I still having problem how to get the ADC results.my flow is..
if object < 10cm, Red LED blink ( connect at RC5)
else if ( 10cm < object < 20cm) , Green LED blink (connect at RC6 )
else if Blue LED blink ( connect at RC7)
Look like very simple for outputs but how can I get the input from RA1??
Please kindly help to explain how can I write the code.Thanks.
---------- Post added at 04:07 ---------- Previous post was at 04:01 ----------
I did try with below code but does not work in hardware.my code start here-
#include <pic.h>
__CONFIG ( 0x3F32 );
#define PORTBIT(adr,bit) ((unsigned)(&adr)*8+(bit)) //no modify this line
static bit led @ PORTBIT(PORTC,5);
void timer1init(void)
/* initialisation of timer1; */
T1CKPS1=1; T1CKPS0=1; /* select prescaler by 8 */
T1OSCEN=0; /* secondary oscillator disabled */
T1SYNC=0;
TMR1CS=0; /* clock source - internal clock */
TMR1ON=1; /* enable timer 1 */
void delayus(unsigned char us)
for (;us--;);
void adcinit(void)
/* initialisation of AD converter */
TRISA = 0xFF; /* all pin of portA are inputs */
ADCON1 = 0x00; /* pin RA1 is analog input */
ADCON0 = 0x49; /* config the converter */
delayus(100);
void settimer1(unsigned int val)
TMR1ON=0;
TMR1IF=0;
TMR1L=val&0xFF;
TMR1H=val>>8;
TMR1ON=1;
unsigned int adcsample(void)
for (ADCON0|=0x04; ADCON0&0x04; ); /* start and wait for done */
return ADRESL|(ADRESH<<8);
void main(void)
unsigned int speed;
TRISC=0x00;
timer1init();
adcinit();
for(;;) {
speed=adcsample();
settimer1(speed);
for(;!TMR1IF;); /* wait for timer1 overflow */
led=!led;
//code end here
I can not see any problems with your code other than
ADCON1 = 0x00;
You need to set bit 7 to right justify the result otherwise the 6 Least Significant bits of ADRESL will always are read as 0.
ADCON1 = 0x80;
Reactions: mncp
    mncp
Hi Sir btbass,
I will change and tried.But my Blue , Red and Green LED all OFF.
Is there any things wrong with my value? I just want to measure the distance.
Please advice. Thanks.
INCLUDE
#include <pic.h>
Configuration Bits
User definition
static bit ledR @ PORTBIT(PORTC,5);
static bit ledG @ PORTBIT(PORTC,6);
static bit ledB @ PORTBIT(PORTC,7);
Program
T1SYNC=0;
for (;us--;);
void adcinit(void)
TRISA = 0xE3; /* all pin of portA are inputs */
TRISC = 0X00;
ADCON1 = 0x08; /* pin RA1 is analog input */
ADON =1;
delayus(100);
TMR1ON=0;
TMR1IF=0;
TMR1L=val&0xFF;
TMR1H=val>>8;
TMR1ON=1;
void main(void)
unsigned int value;
TRISA=0xE3;
timer1init();
adcinit();
for(;;) {
value=adcsample();
settimer1(value);
if (value == 1)
ledG=1;
ledR=1;
ledB=1;
// delayus(100);
else {
ledR=0;
ledG=0;
ledB=0;
Clovis
if (value == 1)
It is very unlikely that the result will be exactly 1?
Try something like
if (value > 20)
Dear btbass,
Thanks for your advice. I tried all possible value 10 to 500 with different sign ( < or > ) but keep blinking Red LED. I do not know what wrongs. I will try to study how to convert analog Voltage to mm/cm (may be there got maths formula) and will let you know and discuss again. Anyway thanks sir.
if (value>20)
ledR=!ledR;
ledG=0;
ledB=0;
//else if ( value < 30)
// ledG=!ledG;
// ledR=0;
// ledB=0;
else
// ledB=!ledB;
ledR=0;
// ledG=0;
Clovis
Hi btbass,
I just try with this code , but LED blink alternatively instead of on one only9in terms of distance) although I did not place any object in fornt of sensor.Any advice Sir?
Thanks.
Clovis
---------- Post added at 07:30 ---------- Previous post was at 07:29 ----------
void main(void)
unsigned int value;
TRISC=0x00;
timer1init();
adcinit();
for(;;) {
value=adcsample();
settimer1(value);
if(value>=200){
ledR=!ledR;
else if(value>=400){
ledG=!ledG;
else if(value>=600){
ledB=!ledB;
This code won't work, it will never get to the last two else if's .
if(value>=200){
  ledR=!ledR;
  ledG=!ledG;
  ledB=!ledB;
You could try
if((value >= 200) && (value < 400)){
  ledR=!ledR;
else if((value >= 400) && (value < 600)){
  ledG=!ledG;
else if(value >= 600){
  ledB=!ledB;
Thanks Sir,I will try it. BTW, i read from this Linearizing Sharp Ranger Data about sharp sensor calculation. R = (2914 / (V + 5)) - 1
But another formula is R = (2194 / (V + 5)) - 1
I do not know which cal data is right. Anyway , I did calculation for 3 V, 2 V and 1V. 3V=313 .., 2v=365 and 1v=438.(base on 2194) and
3V=363 .., 2v=415 and 1v=485.(base on 2914). I try all range.Will get back to you. Thanks.
Clovis
---------- Post added at 02:51 ---------- Previous post was at 01:11 ----------
Hi btbass,
I have tried a lot of code(change here and there for the value),it does not work for me. My programming skill ???? But I did try with blinking LED speed with one LED. It works very good.
I attached the code below. Any idea about how can I change to 3 different LED to output signal depending on distance(voltage)?
Please kindly advice. Thanks in advanced..
#include <pic.h>
Configuration Bits
User definition
//static bit led @ PORTBIT(PORTC,5);
Program
T1SYNC=0;
for (;us--;);
void adcinit(void)
delayus(100);
TMR1ON=0;
TMR1IF=0;
TMR1L=val&0xFF;
TMR1H=val>>8;
TMR1ON=1;
void main(void)
unsigned int blink_speed;
TRISC=0x00;
timer1init();
adcinit();
for(;;) {
blink_speed=adcsample();
settimer1(blink_speed);
ledG=!ledG; //nearer blinking speed faster
//********** Build successful! **********
Clovis.
attached my circuit diagram
  • My_Circuit.zip
Hi sir ,
I attached my circuit n the code below. Any idea about how can I change to 3 different LED to output signal depending on distance(voltage)?
