Dear sir,
Im trying to wind a single phase transformer with UI- Lamination .Instead going with shell type transformer i used UI - core type lamination for my work , where the windings are divided into 2 halfs and winded in both the legs of the coil .While taking the Lead wires i do Parallel the coils for both the primary and secoundry . When i Solved with the FEMM for my reference i can notice the flux linkage is not in the closed path refer the attachement .
As the coils are parallel to each other in my circuit properties i given the current is parallel -Am i right ?
As im dividing the coil will be there any phase difference ?
Kindly suggest me
Best regards
Manoj
