2 loopsticks as a omnidirectional array
dr pepper
Full Member level 6
lancs
I want to prototype an omnidirectional magnetic loopstick ant.
I cannot find much data on the web, maybe I'm not using the right search strings.
Anyway what is a good way to do this, my initial idea is to buffer 2 loopsticks orientated at 90 degrees with 2 fets, then mix the o/p of the fets using 2 windings on a 4 winding balun the third winding of which feeds the rx, the last winding on the balun for tuning connected up to a variable cap.
Or is there a easier idea.
EDIT: Ok I threw this together,
2 fets add the 2 loopstick signals, with a little gain, in order to get the 'signal' into the loopsticks I made them into transformers with the circuit on the left providing excitation, varying the amplitudes of the sources to crudely change the transmitter direction, seems to work.
In real life there might be some weird cancellation issues.
FvM
Super Moderator
Staff member
Bochum, Germany
Good guess. Adding the signals of two 90° oriented coils creates a 45° rotated dipole characteristic. A simple approach for omnidirectionality would be a 90° phase shift network.
dr pepper
Full Member level 6
lancs
Even if I made an all pass filter I'd probably have trouble keeping it aligned.
Any recommendations for an omnidirectional loop for am broadcast?
I'm resisting the silly idea of an arduino and a servo.
FvM
Super Moderator
Staff member
Bochum, Germany
Differential 90° phase shift can be achieved over multiple decades, a standard technique in SSB modulators/demodulators.
As for the omnidirectional loop, think about magnetic field polarizations and the loop orientations to receive it. A vertical polarized field can be received with an omnidirectional horizontal loop, but there's no omidirectional antenna for a horizontal polarized E or H field.
biff44
Advanced Member level 5
New England, USA
for the vertical part, you can also just use a quarterwave whip antenna
so an omnidirectional loop with a vertical whip pointing up from the middle
dr pepper
Full Member level 6
lancs
Wasnt there an rdf antenna that used a loop and a whip to remove one of the directional lobes?
At low freq's however the whip would be huge.
A loop works well, an active whip works but is noisy.
I guess another alternative is to have 2 loops with 2 receiver front ends and some kind of diversity switching based on sig strength.
Edit: I threw this together to see if I could make a simple diversity front end, L1/3 are the loopsticks, they are amplified by a single IF stage, then compared to see which is the strongest signal, that being the one that gets switched through to the final iF.
The circuit needs some more fiddling, plus I used to have an fm diversity receiver, it was a pain when it kept switching, so its probably not a good idea.
LaTeX Commands Quick-Menu:
