2 Dimentional Input/Output Port in Verilog
omara007
Cairo/Egypt
Is it possible to have a 2-D Input (or Output) port declaration in Verilog ?
To my knowledge, it doesn't support two dimensional ports. Its possible to declare ports only as vectors, where the size defines the width of the data bus.
I hope that you are referring to the width and depth as two dimensions of the input/output ports.
It is one of the limitations of Verilog...
not in verilog, but think supported in system verilog using interfaces.
i may be support in verilog-2001
No, neither in Verilog 2005. But System Verilog 2005 introduces a type definition, that can be referenced in module ports. It should allow multidimensional arrays as well as structures in ports.
