2 channel dimmer problem~
takbbb
Junior Member level 2
two channel dimmer
i use mcu to control 2 channel dimmer
However the light bulb lightness was not even
say when i fire @50% duty on 2 triac , one is brighter than other.
can anyone suggest any solution??
pranam77
Advanced Member level 5
INDIA
Are you using the same MCU to fire 2 triacs? and also let me know are the two triacs independently fired are parellelly? And when you dimm 50% with one channel, whats the status of the 2nd one? A schematic would be fine to study the problem.
takbbb
Yes 1 MCU 2 I/O to trigger 2 indepentent triac.
I will post the schematic later
but it 's just basic dimmer circuit with 2 output.
thx anyway~
