kishore2k4
Full Member level 5
- Joined
- Jun 17, 2006
- Messages
- 291
- Helped
- 44
- Reputation
- 88
- Reaction score
- 11
- Trophy points
- 1,298
- Location
- Middle Earth
- Activity points
- 3,295
I am making a radio modem using one of those 2.4Ghz transceivers. The maximum output power will be 20dBm. I am confused about the antenna. I really like to use a microstrip antenna for cost reasons but am worried(lack of knowledge) about the performance. I looked for RF connectors, namely UFL and SMA and they are terribly expensive costing 2 times the transceiver's price in small quantities. I can only guess how much the antennas will cost.
The radio is 802.15-4 compliant with O-QPSK modulation and DSSS over 2Mhz channels in the 2.4Ghz band. They will be used in indoor enviroments so multipath reflections must be considered. The maximum vertical distance between any two radios will not be more than 5 metres so it will be nice if that can used to increase the gain. Also the antenna must be stable enough so that it won't detune everytime some one walks by with a metal coffee mug
I am planning to use a microstrip antenna with the option to use a RF connector (just in case) with a zero-ohm resistor to switch between them. I saw that technique in an application note.
Can someone kindly explain the possible options. Thank You.
