Register Log in
2:1 Multiplexer with open drain Outputs IC
malli_1729
Full Member level 5
INDIA
In our design,
we want to connect a GPIO (3.3V) to 2 devices (selected by another GPIO, one device is 3.3V and other device works with 1.8V.
I am seeing 2:1 mux with Open drain outputs so, that i can connect each output to any voltage(1.8V/3.3V) tolerant device.
any other alternate way to fulfil this in single IC is fine.
malli_1729
Full Member level 5
INDIA
@bking: that's a straight forward 1:2 demux.
Out2 in my diagram is 1.8V (not 3.3V complaint)- these devices with 3.3V VCC will generate Min Voh as 2.4V which will damage 1.8V device....T
That's the reason i asked for open drain outputs....
bking
Member level 5
Maryland, USA
Hmm... I didn't have the post with the picture until now. I see you also flipped it to a 1:2.
How about a 74LS156. That has open collector drivers.
KlausST
Super Moderator
Staff member
An analog MUX usually is bidirectional. I think you don´t need this.
OpenCollector outputs need a pullup. This may be waste of power or slow rising edges.
Thus I think lowVoltage powerd single gates with 3.3V input tolerance could be a good solution without drawback in signals.
But there are informations missing:
HTML:
IN  | SEL || OUT1  | OUT2
 0  |  0  ||   0   |  ?
 0  |  1  ||   ?   |  0
 1  |  0  ||   1   |  ?
 1  |  1  ||   ?   |  1
Please replace the "?" with your desired values.
Klaus
malli_1729
Full Member level 5
INDIA
@bking: Those are old IC's with big packages. I can't fit in my board.
@KlausST: Can you specify which IC can generate this.
I see configurable gates generate 2:1 mux because gates will have multiple inputs and single output.I haven't see any configurable gates which can generate 1:2 DEMUX
KlausST
Super Moderator
Staff member
First you need to give complete informations.
--> replace the "?" with the logic levels you desire.
Klaus
malli_1729
Full Member level 5
INDIA
@KlauST: Thanks,
all '?''s will be replaced by tri-state/disabled as like SN74LVC1G18( 1-of-2 Noninverting Demultiplexer With 3-State Deselected Output).
Basically based on Selection pin IN state should be transferred to OUT1/ OUT2. OUT1 and OUT2 should be Open drain outputs.
KlausST
Super Moderator
Staff member
Why you want tristate? It is an undefined logic level. The receiver may see HIGH or LOW, or oscillation...
Klaus
malli_1729
Full Member level 5
INDIA
"Why you want tristate? It is an undefined logic level. The receiver may see HIGH or LOW, or oscillation..."
--> when it is tri-stated other output will be connected to receiver.
Actual case is,
I have a JTAG chain, with 2 devices connected to a connector (where an ICE or equalent will access the chain to program each device one by one).
Device 1 - 3.3V device
Device 2 - 1.8V device(last in chain)
I need to have option to bypass device2 when required.
TCK,TMS,TST & TDO going to Device2 are going to voltage translating switch(SN74AVC4T245 - name U1) - this translates 3.3V logic to 1.8V logic.
which can disabled by driving OE#
Device1 TDO - can go to Device 2 TDI(in image above it is OUT2) through voltage translating buffer (Device1,Device2 both are in chain) or directly to Connector TDI(when Device2 bypassed- in image it is OUT1)
to implement this,i need a demux(U2)
Case1 : Device2 is bypassed in chain - demux will send IN to Out1
Out2 will be tri-stated,and U1 also disabled by driving OE# of U1
Case2: Device1,Device2 are in chain
demux will select Out2 (from IN),
Out1 will be tristate and U1 will be enabled(OE# LOW), because U1 is enabled TDO from device2 will go to TDO of the connector.
KlausST
Super Moderator
Staff member
Daisy chaining JTAG devices should need no extra logic. It can simply be done with JTAG protocol.
You should be able program to program one device only or both as you like.
You are not the first one to have this problem, thus I recommend to look for existing solutions.
The device manufacturers should provide such informations.
Many JTAG inputs are 3.3V or even 5V tolerant. Please check datasheet.
In case you still want a special solution, then please post a draft/schematic about your idea.
The better your informations the better our chance to help.
Klaus
malli_1729
Full Member level 5
INDIA
"Daisy chaining JTAG devices should need no extra logic. It can simply be done with JTAG protocol.
--> Multi voltage jtag chain requires voltage translators.
If there is a need to bypass/Include certain device on need basis - yes we need to add glue logic to do it.
Below is the ruff implementation.
std_match
Sweden
The original request can be solved with a single 74HC4066 and 4 resistors:
The unmarked resistors should not be critikal. Use 10K or whatever.
The 1k resistor will affect the maximum speed for the 1.8V TDO output. Reduce the value to increase the speed.
std_match
Sweden
I think it would be better to use a MUX on the signal going to the TDO pin on the connector.
If you need to disconnect the ASIC TDI pin when the ASIC is bypassed, use another mux before the 3.3V to 1.8V level converter.
One 74HC157 contains 4 dual-input muxes controlled by the same select input, and should solve the problem.
Toggle Sidebar
