1x4 keypad interfacing
parnal
Newbie level 3
Newbie level 3
please help with the 1x4 keypad interfacing with pic
why 1x4 u can go directly 1 pin for 1 key and check by p0lling.
agree with @embpic. It is better to use 4 keys in on different pins rather than using 1x4 keypad.
And no one gives direct C code, you have to work on it and if you face problem, you can ask here.
yes 4 push button switch will do !
to connect pin required for 1x4 keypad are more than 4 push button switches.;-)
Add a pull up or down resistor according to your requirement!
Reactions: parnal
    parnal
Hello!
i need the c program for dspic30f2011
The purpose of this board is not to do your work (or homework), but to help you in case
you wrote some code and get in trouble running it. Post your code first, and then we'll
see how to help you.
Dora.
dear dora ,
i am not asking you to write up a code for me . i am just asking whether anyone has worked on it so that it will help me out to start up as a beginner . yes i have started working on it and i guess if i have any kind of problem u guys will surely help me out. thank u all for replying ..i appreciate it .
Hello Parnal!
Well, it looks very much like you need some code.
Then if you have a problem, why not posting your code and explaining what's wrong?
Dora.
