Hi MattHi all,
I wish to build a variable lab style SMPS with output voltage from around 1V up to 100V and variable current from 0-10A. I have quite a lot of experience from doing electronics as a hobby for many years as well as studying the subject. I haven't tried anything like this before though. I am building this as part of a university project so this will actually happen and hopefully this thread will be open the next year or so as I progress.
First of all does anyone know of any existing designs which can be modified to achieve the output I want (I've checked I am allowed to do this). I haven't been able to find any so far?
Failing this I have already been looking into designing my own from scratch. I am struggling in choosing a topology, I know flyback is more suited to variable voltage but not suitable for high power and ideally I want to achieve 1KW or at least 500W. At the moment I am going with half bridge but could anyone tell me if this is good idea for variable voltage? I need to have isolation as it will be mains powered.
I have various ideas so far on how to achieve such a wide voltage range from an SMPS with pulse width limitations. So far I am looking at doing one of the following after reaching my lower voltage limit, presumably of 5-10V.
1. Have a second converter running in series off the output of the first which will rechop the waveform a second time and easily reach down to 0V
2. The same about but have two running in parallel.
3. Have a linear regulator stage running from the SMPS secondary which cuts in at a given voltage which will then go down to almost 0V
4. Lower the switching frequency once a given voltage is reached so that a higher mark-space ratio can be realised.
5. Feed the disable pin of a driver chip with a clock signal so that i get a duty cycle of the duty cycle, effectively missing out some pulses.
If anyone could advise which direction to go on with this element that would be great.
I am also struggling with choosing a base switching frequency as I want it to be as low as possible so that I can get the narrowest possible pulses, could anyone advise a starting point?
I also have no idea if any of the 5 suggestions will be needed? It has been suggested that it will not be possible to achieve a 1% duty cycle to give a down to nearly 0V at any reasonable frequency. From my initial calculations this seems likely as I would need a td + tr of around 100nS at a low 40KHz switching freq. There are many Mosfets around this speed or faster, but I'm assuming I would never be able to reach this and get proper pulses in reality?
I haven't looked into it yet but a head start on the best way to have a variable current limit from 0-10A would be great.
I'd really appreciate any help as these questions are really holding me up from making progress with calculations and have done for some time. I probably already have most of the components and a suitable core from being a hobbyist for so many years but I will get on to this later.
As the post is so long I have made questions bold to make it much more readable.
Many Thanks,
Matt.
Probably not. If you're working from 240VAC, then you'll be using ~500V FETs, which will be relatively slow regardless of the load. I'd guess you're looking at 200ns pulse widths at least.I am aiming for 1KW but would anything over about 500W would be good, would this make reaching narrower pulses far easier as I'm trying to avoid things like frequency variation if possible.
Putting more taps on shouldn't really be an issue. Each tap may add a little bit more leakage, but doubt it will matter much overall. The leakage introduced by the relay itself is another question. Also you will likely need to be careful when switching the relay in order to protect components from huge surge currents, and reduce output glitches. Controlling it with a MCU would probably make sense.I really like your idea of multiple taps on a transformer, a relay could switch in somewhere around 30V or 50V and also switch anything required in the control circuit so that as a result pulse width suddenly increases again to compensate for the lost turns, yes? If this is correct this sounds the best solution so far as it would be really simple to implement, the only thing I ask is would it be more challenging to design my own transformer with 2 windings and get proper flux linkage in both.
Half bridge should work well, but it's one of the more difficult topologies to get working. You might also consider using a two switch forward converter topology.The question I most would like to know at the moment though is the basic topology to go with and starting frequency to try?
The major disadvantages of two-switch forward are hard switching and large switching.
Low efficiency is due to several reasons. First, two-switch forward is a hard
switching converter; the switches are hard turn-on and turn-off. This will increase
the switching loss for high frequency operation. Second, two-switch forward has
higher conduction loss compare with half bridge and full bridge converters. This
is because the energy transfer only happens during two switches are on. Because
of transformer reset requirement, the maximum duty cycle can only reach 0.5.
Which means at best, only half of the time this converter can transfer energy to
the output; this will increase the RMS current through the primary switch. With
same reason, the voltage-second on output inductor is much higher in two-switch-
forward converter compared with half bridge and full bridge converter.
Because of these penalties of two-switch forward, it is not so widely used for
this application now.
I would use the half bridge topology, because I've been able to use it in the past successfully. But it's overall a more complicated design, due to issues like flux balancing, current sensing, etc. The two topologies are about the same in terms of dynamic range. If you truly cared about dynamic range more than efficiency, then a flyback would probably be the way to go.Thanks, I have looked into forward converters and found the following.
If you were to build this supply yourself would you still choose the forward topology over the half bridge and if so why as this would be very useful to understand since I can't see much else distinguishing them. Also in what way is is more difficult to get working.
For the switched windings to work you would have to plan how the control loops would handle the sudden change. If you are using a MCU for control, then you can easily build in some nice control scheme to handle the transitions (like making the instantaneous duty inversely proportional to turns ratio). If you use a strictly analog PWM controller, then you have to worry about things like changing loop dynamics, transients on the input and output, etc.Would you still recommend going with switched multiple windings rather than a switched lower frequency introducing a lower feasible duty cycle (although this then requires a variable frequency driver chip since I don't want to have to design that too)?
Many thanks.
