1KW or 5KW smps using flyback topology
emiljose88
Junior Member level 3
kerala,india
I wish to design 1KW or 5KW smps Using Flyback topology. Can You suggest the IC and the circuit.
In theory you can design a flyback with any output power capability, but in practice , cost and efficiency are some of the constrains to limit the implementation of high power flybacks .
There is not a well defined barrier that marks when to use a fyback or a forward or any other topology, but if your design is more than 250 watts, you may consider use other topology instead of a flyback.
http://www.enotes.com/topic/Switched-mode_power_supply
http://www.smps.us/topologies.html
http://www.st.com/internet/com/TECH...AL_LITERATURE/APPLICATION_NOTE/CD00003910.pdf
Before you consider any implementation, in design life, you must state your requirements in a spec. Otherwise it is academic.
One of the best SMPS designers whom I have had the pleasure to work with is Keith Billings when he was at Hammond , I was qualifying his custom designs for Burroughs/Unisys.
Here is one of his lectures. https://docs.google.com/viewer?a=v&...T6-dSi&sig=AHIEtbRIPiQFJL2rvw_8snWpInKSNYRN-g which I found for you on flyback design.
But if you want to make a Tesla generator or a 1kW CPU PSU, you still need specs.
Reactions: mtwieg
    mtwieg
Forward topology at 1KW? (Not to mention the 5KW... :roll: ) At this level of power I consider it’s better using half-bridge / full-bridge instead.
If you are serious about building a 1KW SMPS maybe need to start with a smaller one. The SMPS are hard to design and build, read as much as you can (many of the application notes by the component suppliers are more useful than stuff on the general web). At the >1Kw level you start getting into expensive semiconductors and one blow up is enough to ruin such a project.
  • SMPS_SH.pdf
thanks
Is it possible for 250W (UC3842) 12V 10A or 15A? In forward topology?
