I use MikroC Pro and PICKit2. Can anybody tell me how to do this
for (i=0; i<16;i++){
save (i) in mmc card
and also read saved data when necessory.
thanks
No problem. The Data Logger project should get you started in the right direction. However, you need to be aware that MMC and SD cards are 3.3v not 5v. Therefore you'll either need to find a breakout board with a 3.3v voltage regulator or build your own. They both use a SPI interface.
