AVR compiler and programmer
bhoomi_shah2906
Member level 1
I am using the ICCAVR software for writing the program. I am using ATMEGA32 controller. TO program the controller can i use the PONYPROG software, which is universal serial programming software...
i dont have any AVR kit.. just want to program by connecting 6 programming pin for SPI..
so ICCAVR and the PRONYPROG software are compatible or not??
if anyone knows please help me..
Or the simple LPT programer, works too with pony.
Reactions: mintu
    mintu
In CVAVR use kanada/stk200 settings -like this:
last is pony setup for this programmer.
!!!!!BE careful can burn LPT PORT!!!
Use this is safe to use :
zero1 i made this programmer but it is not able program the chip. i always got write failed.
where is the problem?
santoshaxl thnx...
i have made the same circuit and its working with the ponyprog...
can we use this same circuit for programming using AVR STUDIO or BASCOm???
please do reply....
Uninstal from DManeger /if use Windows XP/ LPT port,then go to find new device
then reboot the PC.Some driver may cause this.
In AVR Studio this programmer is not in the list!Use a AVR 910 or STK 500,links :
http://prottoss.com/projects/AVR910.usb.prog/avr910_usb_programmer.htm
http://micha.freeshell.org/avr/AVR910/AVR910.html
STK 500 http://prottoss.com/projects/ucGoZilla/ucGoZilla.htm
http://www.der-hammer.info/hvprog/index_en.htm
In Bascom AVR programmers are:
AVR ISP
STK200/300 -/This is 5cables programmer/
PG302
EXTERNAL PROGRAMMER
SAMPLE ELECTRONICS PROGRAMMER
And more,stk500 ,avr isp mkll and more.
my version is 1.11.9.5
with this verson avr910 do not work fine!!!
