generate pink noise using Voss-McCartney algorithm
woeichee
Newbie level 5
Malaysia
Pink Noise
Hi. I am trying to generate pink noise using Voss-McCartney algorithm.
The way how i generate 1st row noise:
1. Call a random function
2. Update the output every 2 cycle. (e.g. 3,3, 57, 57, 100, 100...)
3. 1048576 samples was used in FFT
The fft output as attached:
The problem is:
1. I din get the ripple at high frequency as shown in https://www.firstpr.com.au/dsp/pink-noise/allan-2/spectrum2.html
Any problem with the flow above?
Thanks
Re: Pink Noise
Hi woeichee,
The spectrum you obtained is essentially the same as in the reference (https://www.firstpr.com.au/dsp/pink-noise/allan-2/spectrum2.html) for the Row 1. It looks different for these reasons:
1) Your spectrum goes from 0 to the Nyquist frequency (i.e. from bin 0 to 512K in your scale), while the reference shows the complete fft (up to the sampling frequency, i.e. 2*pi). So, the fall at the end of your plot is the notch at half the frequency in the reference (pi). Note that the normalizations (horizontal scale) are different in your plot and in the reference.
2) Your plot is linear in the hirizontal (frequency) axis while in the reference is log, so compressed in the right part and expanded in the left part.
3) In the reference is theoretical (smooth) while yours is an estimation from a single realization without averaging (fat yellow band).
With more rows it should look more "pink". Use log frequency scale for see it.
Regards
Z
From my understanding, there is no way to plot more than half sampling frequency. Besides, any freq above nyquist freq will be having a mirror of signal, right? Why there is a ripple instead of mirror image?
May i know how to plot more than half sampling frequency? So that i can see the ripple.
Besides, what is the ohm in horizontal scale represent?
thanks a lot
Hi woeichee,
Discrete (or Fast) Fourier Transforms calculates values for frequencies ranging from 0 to Fsampling (or alternatively from -Fsampling/2 to Fsampling/2).
It is true that for real signals the spectrum has simmetry around frequency 0 or Fsampling/2 (and then only one half is sufficient), but this is not the case for complex signals.
Please tell which figure are you speaking of.
That depends of the application you use for the plot. There sould be a way to calculate and represent the whole spectrum.
"Omega" represents normalized angular frequency, measured in radians per sample. Nyquist frequency corresponds to Ω=pi; sampling frequency corresponds to Ω=2*pi.
woeichee said:
thanks a lot
You're welcome
Regards
Z
How to determine a signal is complex signal or real signal? From my point of view, every value of each row generated by random function is real. So, it should be the real signal. May i know why you call it complex signal? Is it relates to the euler identity? Pls elaborate in details.
In the case of complex signal, then what i ask is not valid d.
That depends of the application you use for the plot. There should be a way to calculate and represent the whole spectrum.
Can you suggest me a reference to me? so, that i can try to plot a graph that more than Nyquist frequency.
Since Ω=2*pi, why the graph shown in that website can plot unitl 10&#937?
If plot more than 2*pi, doesn't it will show the repeating signal?
I am just a beginner. So, pls tolerate if i ask a silly question... thx
You are generating real signals, but you could generate complex as well with real and imaginary parts. Compex signals are used a lot in communications (I and Q components in modulation-demodulation, etc.) and signal processing. Look in communications and signal processing books.
For example, fft functions in Matlab computes the whole spectrum. What program are using you?
Since Ω=2*pi, why the graph shown in that website can plot unitl 10Ω?
The axis goes until 10 because it is in log scale and covers whole decades, but the plot stops at Ω=2*pi (6.28...).
Regards
Z
Basically, you are talking the pink noise plotted on that website is generated by complex signal, since you mention that the spectrum i attached is limited by Nyquist frequency. Am i right? if that is the case, how to generate a random number with imaginary part? Is it using a 2 random function: one as real part and another one is imaginary part?
I am using Agilent VEE. e.g Perform 1024 point fft will generate 513 point (real and imaginary)
Hi woeichee,
No. I intended to answer this question:
telling that Fourier Transforms of complex signals don't have that symmetry. Signal of the website seems to be real; its spectrum looks symmetrical.
Yes.
I don't know if it has an option for generate the whole spectrum. You have the spectrum from 0 up to Fsamp/2 for a real signal. This is OK for real signals. So, your spectra will look like the first half of those of the website. If you want to reproduce the figures of the website, you need the whole spectrum.
Regards
Z
