you may get some code from yhis programe pls gothrough it (Hitachi LCD HD44780 module)
LIST P=16C84;f=inhx8m
; these are directives for the programmer to set various fuses in the 16C84
_CP_OFF equ H'3FFF' ;code protect off
_PWRTE_ON equ H'3FFF' ;Power on timer on
_WDT_OFF equ H'3FFB' ;watch dog timer off
_XT_OSC equ H'3FFD' ;crystal oscillator
__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
;configure directive
w equ 0 ; destination numbers.
f equ 1
same equ 1
z equ 2 ; status bits
zero equ 2
c equ 0
carry equ 0
ind equ 00 ; indirect register f0
pc equ 02 ; program counter f2
status equ 03 ; status register f3
fsr equ 04 ; file select register.
; contents are used as an address
; when you operate on f0
porta equ 05 ; port a I/O register f5
portb equ 06 ; port b I/O register f6
LCDcontrol = porta ;Control lines to LCD
RW = 2
RS = 1
E = 0
LCDdata = portb
count = 3 ;Number of characters
; LCD commands follow
wide = b'111000' ; 8 bit interface
narrow = b'101000' ; 4 bit interface
clear = 1 ; clear display
home = b'10' ; cursor home
ns_dec = b'100' ; no shift, decrement
s_dec = b'101' ; shift, decrement
ns_inc = b'110' ; no shift, increment
s_inc = b'111' ; shift, increment
dispon = b'1100' ; display on, cursor off, blink off
dispoff = b'1000' ; display off
cur_line = b'1110' ; line cursor
cur_blk = b'1111' ; block cursor
curR = b'10100' ; move cursor right
curL = b'10000' ; move cursor left
movR = b'11100' ; shift display right
movL = b'11000' ; shift display left
; Set RAM origin above special registers, declare variables, and set code
; origin.
cblock 0C
temp ;Temporary counter.
temp2 ;Pass data or instructions to blip_E.
counter ;Index variable.
tmp_bit ;Temp to store RS bit value
tmp_w
tmp_s
tmp_bit1
tmp_bit2
dig1 ; counter display digits.
dig2
dig3
dig4
endc
org 0
goto start
org 5
start movlw 0 ;Initialize ports, power LCD and wait
movwf porta ;for it to reset.
movlw 0
movwf tmp_bit
movlw 0
movwf portb
movlw 0
tris porta ;Set control lines to output
movlw 0
tris portb
bsf LCDcontrol,pwr
call wait
;LCD FUNCTIONS initialize
movlw wide
movwf temp2 ;Initialize LCD: set 8-bit, 2-line
; 2 lines due to a 1 IC LCD display
call blip_E ;Send data
;LCD set DISPLAY
movlw dispon
movwf temp2 ;Display ON, Cursor OFF
;LCD set ENTRY MODE
movlw ns_inc
movwf temp2 ;Increment Pointer,no display shift
;LCD set DD RAM
bcf LCDcontrol,RS ;Set control register
movlw b'10000000'
movwf temp2 ;Write to DD RAM at address 0.
call blip_E ;send data
init_digs movlw 30
movwf dig1
movlw 30
movwf dig2
movlw 30
movwf dig3
movlw 30
movwf dig4
stopwatch call send_alpha
first call wait
call update
incf dig1
movlw 3A
subwf dig1,w
btfss status,c
goto first
movlw 30
movwf dig1
second incf dig2
movlw 3A
subwf dig2,w
btfss status,c
goto first
movlw 30
movwf dig2
third incf dig3
movlw 3A
subwf dig3,w
btfss status,c
goto first
movlw 30
movwf dig3
fourth incf dig4
movlw 3A
subwf dig4,w
btfss status,c
goto first
goto init_digs ;run program again.
;SUBROUTINES
send_alpha bsf LCDcontrol,RS ;set data register
movlw 0
movwf counter ;Send the message string to the LCD.
loopalpha movf counter,w
call msg
movwf temp2
call blip_E
incf counter ; counter+=1
movlw count
subwf counter,w
btfss status,c
goto loopalpha
return
blip_E ;Store current state of RS
btfss LCDcontrol,RS ;bit test skip next if set
bcf tmp_bit1,0 ;clear temp bit
btfsc LCDcontrol,RS ;bit test skip next if clear
bsf tmp_bit1,0 ;set temp bit
bcf LCDcontrol,RS ;Clear RS to send instruction.
bsf LCDcontrol,RW ;Set RW to read.
movlw b'11111111'
tris portb ;Portb all inputs.
busy bsf LCDcontrol,E ;Enable the LCD.
nop
movf LCDdata,w
movwf temp ;Put LCD data (rb) into temp.
bcf LCDcontrol,E ;Disable LCD.
btfsc temp,7 ;Is the LCD busy?
goto busy ;Yes, try again later.
btfss tmp_bit1,0 ; No send the data or instruction
bcf LCDcontrol,RS
btfsc tmp_bit1,0
bsf LCDcontrol,RS
bcf LCDcontrol,RW
movlw 0
tris portb ;Portb all outputs.
movf temp2,w
movwf LCDdata
bsf LCDcontrol,E
nop
bcf LCDcontrol,E
return
wait movlw .200
movwf temp2 ;Create a delay for LCD power-on reset.
delay decfsz temp
goto delay
decfsz temp2
goto delay
return
msg addwf pc,same ; Table of characters to display.
retlw 'm'
retlw 'w'
retlw 'r'
update bcf LCDcontrol,RS ; set control register
movlw b'10000101' ; move to 5th character along
movwf temp2
call blip_E
bsf LCDcontrol,RS ; set data register
movlw 4
movlw dig4
movwf fsr ;put base address of digits in fsr
loop movf ind,w ;get indirected digit
movwf temp2
call blip_E
decf fsr
decf counter ; counter-=1
movf counter,w ; get counter back for zero test
btfss status,z
goto loop
return
END
---------- Post added at 09:29 ---------- Previous post was at 09:26 ----------
Some Useful Commands here for you friend
Command (in hex) Effect
0C Turns ON JUST the LCD, no cursor
08 Turns OFF the LCD display
0E Turns on the LCD display and Sets a SOLID CURSOR
0F Turns on the LCD display and Sets a BLINKING CURSOR
80 Moves cursor to first address on the left of LINE 1
C0 Moves cursor to first address on the left of LINE 2
94 Moves cursor to first address on the left of LINE 3
D4 Moves cursor to first address on the left of LINE 4
