16x2 LCD interface to PIC 16F877.
breoTechAT529
Newbie level 3
Pretoria,South Africa
I am new at this so please bear with me. I need help with the LCD.i am using it in 8 bit mode . the LCD is not even on although everything is connected. I could be making a silly mistake.Need help debugging.
amraldo
Egypt
There is an example of building a digital clock using this chip. You can take the LCD part from there and compare it to yours.
Check the code of picnote https://picnote.blogspot.com/2008/06/ds1307-pic16f877a.html.
It contains LCD code in C.
You can download MikroC evaluation and it will work with the code.
Amr
amraldo
Egypt
Thats good. Actually the MikroC manual have good examples you can build on top of them.
Amr
breoTechAT529
Newbie level 3
I want to use my LCD to display , but only one line is on.its a 16x2 screen.how can I turn it on OR could the device be faulty ? is there a simpler way of creating a schmitt trigger input without having to build a special circuit for it ?
