amit.kumar11
Member level 5
Dear All,
I am using a 16x2 LCD. I have around 15 no LCD modules. 3 LCDs are working fine but with some of the LCD i am facing issue with contrast pin. If I switch on the board, everything is coming fine but after some time display is going to full brightness mode. I checked the Vo pin voltage its going to 4.5V. Initially its around 0.8V which is opk for contrast pin.
I am not able to understand, why suddenly Vo voltage starts varying.
Also If i disconnect LCD module from my board, then voltage at Vo pin in my board is stable.
Any help will be appreciated.
LCD part number-NHD-0216K1Z-FL-YBW
Amit
Amit
