sam217
Newbie level 3
This is my program to interface LCD with PIC DEM 2 plus (18f4520 pic microcontroller).when i m trying tgo display single charcter then its working fine but wen i want to display string some jumbled dchars r being displayed.plz help me.
#include <p18f4520.h>
#pragma config WDT=OFF
#define LCD_RS LATDbits.LATD4 // Register select
#define LCD_EN LATDbits.LATD6 // Enable
#define LCD_RW LATDbits.LATD5 // Read write
#define LCD_D4 LATDbits.LATD0 // Data bits
#define LCD_D5 LATDbits.LATD1 // Data bits
#define LCD_D6 LATDbits.LATD2 // Data bits
#define LCD_D7 LATDbits.LATD3 // Data bits
#define LCD_STROBE ((LCD_EN = 1),(LCD_EN=0))
void lcd_write(unsigned char);
void lcd_clear(void);
void lcd_puts(unsigned char * );
void lcd_putch(unsigned char );
void lcd_goto1(unsigned char );
void lcd_goto2(unsigned char );
void lcd_init(void);
void Delay(unsigned int);
unsigned int j=0;
/* write a byte to the LCD in 4 bit mode */
void lcd_write(unsigned char c)
PORTD = (PORTD & 0xF0) | (c >> 4);
LCD_STROBE;
PORTD = (PORTD & 0xF0) | (c & 0x0F);
LCD_STROBE;
Delay(400);
* Clear the LCD
LCD_RS = 0;
LCD_RW=0;
lcd_write(0x1);
Delay(2);
/* write a string of chars to the LCD */
void lcd_puts(unsigned char * s)
LCD_RS = 1; // write characters
while(*s)
lcd_write(*s++);
/* write one character to the LCD */
void lcd_putch(unsigned char c)
LCD_RS =1; // write characters
lcd_write(c);
/*void lcd_puts(char str[15]) {
char d;
while(str!='\0') {
d = str ;
lcd_write(d);
* Go to the specified position in line 1
void lcd_goto1(unsigned char pos)
LCD_RS = 0;
lcd_write(0x80 + pos);
* Go to the specified position in line 2
void lcd_goto2(unsigned char pos)
LCD_RS = 0;
lcd_write(0xC0 + pos);
/* initialise the LCD - put into 4 bit mode */
void lcd_init(void)
LCD_RS = 0; // write control bytes
Delay(150);// power on delay
LCD_D4 = 1; // init!
LCD_D5 = 1; //
LCD_STROBE;
Delay(50);
LCD_STROBE; // init!
Delay(1000);
Delay(50);
LCD_D4 = 0; // set 4 bit mode
LCD_STROBE;
Delay(400);
lcd_write(0x28);// 4 bit mode, 1/16 duty, 5x8 font, 2lines
lcd_write(0x0C);// display on
lcd_write(0x06);// entry mode
lcd_write(0x01);// clear display and reset cursor
void main()
TRISD=0X00; //port D as o/p
PORTD=0X00; //clear port D
lcd_init(); //initialize lcd
lcd_goto1(1);
lcd_putch('H');/*Hi ! is being displayed
lcd_putch('i');
lcd_putch('!');
lcd_puts("Welcome"); //but lcd_puts is not working garbage datas are being dislayed
for(;
void Delay(unsigned int i)
unsigned int j;
for(j=0;j<i;j++);
unsigned int j=0;
LCD_STROBE;
LCD_STROBE;
Delay(400);
* Clear the LCD
LCD_RS = 0;
LCD_RW=0;
lcd_write(0x1);
Delay(2);
while(*s)
lcd_write(*s++);
lcd_write(c);
char d;
while(str!='\0') {
d = str ;
lcd_write(d);
LCD_RS = 0;
LCD_RS = 0;
void lcd_init(void)
LCD_D5 = 1; //
LCD_STROBE;
Delay(50);
Delay(1000);
Delay(50);
LCD_STROBE;
Delay(400);
void main()
lcd_goto1(1);
lcd_putch('i');
lcd_putch('!');
for(;
unsigned int j;
for(j=0;j<i;j++);
