16f876A directly interfacing repay?
neazoi
Advanced Member level 5
Greece
Hello, I need a little bit of help here
I would like to use the 16f876A or similar 28-pin micro to switch on/of some relays.
If the relays have a 5V coil, can I switch them on by directly connecting the microcontroller pin to the coil, or do I need a transistor switch?
I prefer driving the relay directly but I do not know how much current can the micro provide on each pin.
The relays coils datasheet is this one https://www.techno-star.biz/relays/ea2.pdf
Also what about latch type relays, which require current only when switching? Would I be able to directly drive their coils using the micro?
hussain_kiet
Full Member level 5
Karachi, Pakistan
it is recommended that you need a transistor to switch the relay other wise it may damage your controller...
Reactions: neazoi
    neazoi
neazoi
Greece
Even if I use latch type relays?
What is the max output current of the 16f876A btw?
horace1
Norwich, UK
I agree with hussain_kiet to use a transistor such as a BSP130 D-MOS logic level FET to drive the relay. Also if the relay is switching high currents or voltages an opto isolator before the replay is a good idea.
abidr
Full Member level 5
33 N, 73 E
It depends on the type and number of relays.
If number of relays is more than 1, I would personally prefer using a ULN2003.
