itsallgood
Member level 2
16f628 internal oscillator
Hi guys,
I've still not really worked out these pesky chips -- im gussing it'll be easier once i buy some and have a mess around, instead of just using simulators, anyway, im reading this site here: http://www.winpicprog.co.uk/pic_tutorial.htm
And the source the site gives you turns on the internal oscillator, which im guessing means you dont have to have the crystal on the OSC1/2 legs.
But i'm using picbasic pro, so dont know how to set it up to use the internal oscillator. -- i'm using MicroCode Studio to run the picbasic pro, my code is just:
loop:
high 0
pause 100
low 0
pause 100
goto loop
end
is there some line of code i need to do before this to make it use the internal oscillator???
Thanks very much,
Regards.
Hi guys,
loop:
high 0
pause 100
low 0
pause 100
goto loop
end
Thanks very much,
Regards.
