Control 12v Dc motor speed using 8051.
vudiepdh1
Junior Member level 1
Viet Nam
Hi all ! I want to control 12v Dc motor speed using 8051. Many people say i should use Pwm to control motor speed . So please tell me how does it work and how to do it with 8051 . I am using c ! Thank
No worries ..
Don’t forget about a driver (BJT or MOSFET) between microcontroller and motor ..
In both cases working with the 8051-derivatives require a 10k (or less) pull-up resistor attached to the pin that drives the MOSFET ..
See attached picture ..
Rgds,
IanP
Thank for reply Ianp ! I have got some transistor H1061 . Can i use it in this case !?
Hallo,
You must know; they are BJT, 100V max 4A !
These transistors hase Hfe(~Beta) min 50>> if your motor need 2-3A, their Ibasis will be 2A/50=40mA, you need maybe an ULN or a second transistor (basis)driver and resistors in the basis circuits...
K.
I like to add additional comment for your requirement. Think about the feedback part of the motor to maintain speed. if the accuracy of the motor speed really required.
In this case you can use motor with encoder to give feedback to the controller
more information about the optical encoder found from https://en.wikipedia.org/wiki/Rotary_encoder
regards
bassa
Hi, I am using L293 as transistor. I am wondering if I can use L293 with 8051 PWM?
