[SOLVED] 16 x 2 LCD interfacing problem
Venkadesh_M
Coimbatore, India
Hi all,
I am using PIC 16f877A with lcd jhd 162a. I am trying to interfacing in a 4 bit mode.
I am doing all this
sending command as said in manual and followed by data
but i am getting clear screen on first line and block boxes on second line.
0x3
0x3
0x3
0x28 //for 4 bit mode
0x08
0x38
0x01 // clear display
after that i am sending data to LCD
I am very new to lcd please help me.....
i think u need check you connection TX RX
sorry i mean: ur config....
if u use Mikroc
// LCD module connections
sbit LCD_RS at RB5_bit;
sbit LCD_EN at RB7_bit;
sbit LCD_D4 at RC4_bit;
sbit LCD_D5 at RC5_bit;
sbit LCD_D6 at RC6_bit;
sbit LCD_D7 at RC7_bit;
sbit LCD_RS_Direction at TRISB5_bit;
sbit LCD_EN_Direction at TRISB7_bit;
sbit LCD_D4_Direction at TRISC4_bit;
sbit LCD_D5_Direction at TRISC5_bit;
sbit LCD_D6_Direction at TRISC6_bit;
sbit LCD_D7_Direction at TRISC7_bit;
// End LCD module connections
void main()
 Lcd_Init(); // Initialize LCD
 Lcd_Cmd(_LCD_CLEAR); // Clear display
 Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
 Lcd_Out(1,1,"Hello World");//Write text'Hello World' in first row
U really Bad boy if don't know don't reply
U connect lower port or higher port bit for sending data . also after each place few ms delay which is compulsory
delay1(3500);
lcd_write_nibble(ctrl_instr,0x03);
delay1(5000);
delay1(250);
delay1(250);
lcd_write_nibble(ctrl_instr,0x02);
delay1(250);
lcd_write_nibble(ctrl_instr,0x08);
delay1(10);
lcd_write_nibble(ctrl_instr,0x00);
delay1(10);
lcd_write_nibble(ctrl_instr,0x0C);
delay1(10);
Golden electronics for my doubt i given 30ms delay between enable as well as each instruction. still its not working it makes clearing display in upper row.
is that a over delay or any mistake in commanding sequence??
please clear me ur hardware pin details means which pin used. Can u check is ur controller working for this u may blink any led cont.. sill problem then inform i send details according to ur code
Ya I checked other ports with output LEDs everything works fine. and the portd LCD pins also changing.
I am adding the codes here please check and found out . .
#include <pic.h>
#include <htc.h>
#define _XTAL_FREQ 20000000
#define RW RD2
#define RS RD3
#define EN RD1
#define databits PORTD
void delay_ms(void)
__delay_ms(31);
__delay_ms(31);
__delay_ms(31);
void data(unsigned char c)
	delay_ms();
 	databits = ( c & 0xF0 ) | 0x08 | 0x02;
   	delay_ms();
	databits = ( c & 0XF0 ) | 0x08;
        delay_ms();
        databits = ( ( c << 4 ) & 0xF0 ) | 0x08 | 0x02;
        delay_ms();
	databits = ( ( c << 4 ) & 0XF0 ) | 0x08;
	delay_ms();
void cmd(unsigned char c)
	delay_ms();
 	databits = ( c & 0xF0 ) | 0x02;
       delay_ms();
	databits = ( c & 0XF0 );
        delay_ms();
 	databits = ( ( c << 4 ) & 0xF0 ) | 0x02;
        delay_ms();
	databits = ( ( c << 4 ) & 0XF0 );
	delay_ms();
main()
        TRISD = 0;
	TRISC = 0;
	delay_ms();
        delay_ms();
        delay_ms();
        delay_ms();
        cmd(0x33);
        delay_ms();
	cmd(0x32);
        delay_ms();
	cmd(0x28);
        delay_ms();
	cmd(0x08);
        delay_ms();
	cmd(0x01);
        delay_ms();
	cmd(0x06);
	RC1 = 1;
        delay_ms();
	data('V');
        delay_ms();
	data('E');
        delay_ms();
	data('N');
        delay_ms();
	data('K');
        delay_ms();
	data('A');
        delay_ms();
	data('D');
        delay_ms();
	data('E');
        delay_ms();
	data('S');
        delay_ms();
	data('H');
	RC0 = 1;
RD7 to DB7
RD6 to DB6
RD5 to DB5
RD4 to DB4
RD3 to RS
RD2 to RW
RD1 to EN
Use CCS C compiler.....
Its easy to code and decode.
Venkadeshm,
try to sync LCD to processor, may be they are running at different speeds
0x03
0x03
0x03
0x02 // you add this
first go to basics how you are sending a command and data to LCD.
command mode should go like this
data=buf//read buff
Rs=0,
Rw=0,
En =1,
some delay
En=0
data mode should go like this
Rs=1
Rw=0
En =1
some delay
En=0
no where you mentioned so while sending data , you just masked the data .
learn to comment your code, others have to understand what you are sending to suggest you.
** Use library functions it would be better
Thankyou Raady,
I mentioned the pin assignments in a particular port and I am packing the data as for the required RS and En inputs,
Commonly every one doing so thats why i didnt mentioned it..
Thanks for all............
My lcd is working very very fine....
What i did wrong is i didnt on the display, i just follow the procedure to initialize the lcd in its manual...
now its looks easy and fine thank you all...
#include <pic.h>
#include <htc.h>
#define RW RD2
#define RS RD3
#define EN RD1
   	__delay_us(50);
    __delay_us(50);
    __delay_us(50);
   	__delay_us(50);
    __delay_us(50);
    __delay_us(50);
void init(unsigned char c)
   	__delay_us(50);
    __delay_ms(10);
    __delay_us(50);
void puts(char* str)
	cmd(0x01);
	cmd(0x80);
	__delay_ms(31);
    for(char i = 0; str[i] != 0; i++)
    __delay_us(20);
	data(str[i]);
void lcd_init(void)
    __delay_ms(16);
    init(0x33);
    __delay_ms(1);
	cmd(0x32);
    __delay_us(20);
	cmd(0x2C);
    __delay_us(20);
	cmd(0x0C);
    __delay_us(20);
	cmd(0x06);
	__delay_us(20);
	cmd(0x0C);
	__delay_us(20);
	cmd(0x01);
    __delay_us(20);
	cmd(0x80);
    __delay_us(20);
main()
	char i, wel[]="    WELCOME";
    TRISD = 0;
	TRISC = 0;
	RC0 = RC1 = RC2 = 0;
	lcd_init();
	puts(wel);
	for( i = 0; i < 50; i++)
	__delay_ms(30);
	while(1);
read this i think it really can help u
