16-bit Timer for PIC18F452
angadaria
Junior Member level 2
hi i m trying to learn the timer for PIC18F452...please anyone can help me out about how to configure the timer and how to use TMR1L and TMR1H registers...
many thanks
akshay gadaria
hi thank you for your suggestions both of you..
accordingly i tried to write the basic code on my own just to check the overflow of the timer but it is not working. timer overflow flag is not getting set.
i m using PIC16F877A with 8MHz frequency and i m using MikroC PRo for PIC IDE. can u please check the code and let me know what is the error or what is missing?
void main()
TRISC=0x00; //configure port c as an o/p port
while(1)
PIE1=0x01; //enables the timer1 overflow interrupt
PIR1=0x00; //clear the timer overflow flag
INTCON=0xc0; //enables the global and peripheral interrupt
T1CON |=(1<<TMR1ON); //start the timer
while(TMR1IF==0); //polling the overflow flag
PORTC=0x55;
PIR1=0x00; //clear the interrupt flag
