sudarshann
Junior Member level 2
Hi
I am in need of a DC Supply 15V @ 3A.
My requirements are 15V-18V is the limit i need which does not mean i need to vary between the limit. the supply can be with the at limit any value for the device(https://www.hobbyking.com/hobbyking...O6_50W_5A_Balancer_Charger_w_accessories.html).
so i tried with a transformer 0-15V 3A rating i connected a bridge rectifier rated 4A and Capacitor 1000uf
i get a output of 22.XX volt as output. any my device says over voltage.
how can i reduce the voltage to the limit between 15-18 Volt. I tried to find some suitable voltage regulators but i couldnt get them in my local shops.
is there any other simple solution to reduce the voltage. can i use resistors if so what value and power rating.
i know that voltage will drop when the load is connected but this device is intelligent it detects the voltage even before connecting to load.
any solution welcomed
Thank you
Thank you
