feifei1201
Newbie level 1
Hi all
Thanks for your help.
I'm simulating a curve antenna under 13.56MHz . Thickness is 5um. Width is 76um.
practically, I measured the inductance is 5.5uH.
But the simulation result is 300uH with single lumped port.
I tried double lumped ports. The result is 54uH.
My settings are as follow:
solution frequency 13.56MHz
sweep type is interpolating.
frequency setup if 13MHz-14MHz 0.01MHz
There are two questions,
1.Should I set single lumped port or double lumped ports? why
2.By which method can I get about 5.5uH in simulation ?
thank you for your help
