12W LED light controller?!!
Navid T
Full Member level 3
Iran
Hi friends
I have a 12W LED ( 12X1W ), I need a circuit to control it's light, i use this circuit but after few hours pot heat goes up and makes problem. what do you suggest to control light of 12W led with potentiometer?
Regards
kam1787
Advanced Member level 3
English
use a 20k or 50k pot
and
try;
- using a 2n3055 with higher gain; hfe
or
- use a darlington for Q1
or
- use a different Q1 with higher gain
Navid T
Full Member level 3
Iran
thanks for answer
I have uased 20K pot before 1K and i had same problem, my resistors are 5W resistor, 2n3055 max collector current is 75A and in this circuit max current is 1A, main problem is POT!! anyway i try 50K too :)
Thanks
kam1787
English
does it happen at full power? Sorry - I jumped too soon - - I think the value of R1 is too low. Increase the pot [ 20K s/b ok ] and R1. The "upper side" of the pot and R1 are setting the current - you have too much current flowing when at or near full power. Q1 needs too much base current for the pot.
But after increasing the pot and R1, Q1 may not be able to drive the LED to full power.
then you have to;
- use a 2n3055 with higher gain; hfe
or
or
R1 does not have to be 5W.
It would be better [less power wasted] to control it using PWM. A simple 555 based circuit can have a duty cycle from 50% to 99%.
A little more complex 555 circuit has a broader duty cycle.
Or you could control the current rather than the voltage.
Navid T
Full Member level 3
Iran
Thanks Kam, i'll do everything you say and i'm sure i'll get what i want:)
Navid T
Full Member level 3
Iran
as my customer said i changed this circuit from base, i used a selector key tu have 4 different light with 4 different 5W resistor, i'll try this circuit when i'll be free too:)
best regards for you attention kam :)
