Awarapunshee said:gabriel2000 said:kindly help me for 12vdc to 220vac 500watts up inverter circuit diagram please help thanks
Regards
WimRFP said:Hello,
When you really want sine wave output, you first have to build a 12V to 350..400V isolated converter. This high voltage feeds a full bridge (H-bridge) stage that is PWM modulated with above 20kHz.
A simple LC filter (with small ferrite core) removes the above 20 kHz switching frequency.
This H-bridge approach also can handle inductive loads as the inductive kick is fed back to the DC bus voltage. From a practical point of view, forget filtering a square wave output to get a sine wave output.
Depending on the availability of components, you may consider IGBT's for the H-bridge (check whether there is freewheel diode in it, if not you need 4 fast recovery diodes also).
