riwalker
Junior Member level 1
Please help.
Months of experiments came to naught.
we need 5A from 12VAC on 12AWG.
we cannot change 12VAC, its used in the industry exclusively.
Switching to 15VAC does get us to 4A max on 12AWG@250ft and maybe an option.
We could force customers to use heavier cable, but retrofit was a goal.
I am trying to pull 5A from 12VAC on a 250ft line, and max I can do is 2.5A with a BOOST circuit
The issue is the drop in volts after the bridge rectifier, even if I use ‘ideal’ bridge, or even 'bridge doubler', the volts drop dramatically such that not enough (>2V) to energise a buck-boost controller.
best from 12VAC is 2.5A@250ft, 1.5A@500ft
have heard that 'bridgeless' / 'totem-pole' / 'active full bridge' PFC may help, also BCM (Boundary Conduction Mode) would help, but all circuits out there are designed for 120-240V with ASIC minimums typically 22V.
also read the thread that bridgeless OFC is an EMC nightmare ? hence dotn want to embark on something that will never work
I sincerely appreciate any insight, as I am truly stuck.
