12v to 24v boost converter with 10-15a of current
aq_mishu
Full Member level 4
Full Member level 4
Guys,
I need a boost converter that could deliver 10 to 15amps of current at 24v, constantly.
Now we can max get around 1a. Any ideas for such. Large current??
Mishu.
A discrete design using a boost control IC, 40A mosfet, 100V rated, 45V 30A schottky diode, suitable choke, o/p caps, input filtering, heatsinking...
:eek:) AC
Interleaving is definitely effective for >100W designs. Recently I designed a two phase 28V 400W boost using a LTC3787 controller, it worked well with efficiency >95%.
Guys,
Forgot to tell you the big part, here in my country, i dont have any special ics. I can use uC for pwm and monitor for feedback. But above all, how should i achieve high current? Currently we are getting max 1.25 Amps at output.
Also, what is the meaning of interleaving here?? Cnfused...
Mishu.
Here is a simplified concept of a quadruple interleaved boost converter.
The load receives 24V at 15A. (I made an assumption that the supply is 12V.)
It is about 85% efficient (in theory).
You would probably use mosfets for the switches.
You would need to join several capacitors, because there will be over 6 A going back and forth through them continually.
Dear sir, this looks interesting. Can you describe a bit more on this? Or some link? I googled and found nothing. It looks paralleling them, but why multiple cloks?? Its not like exact paralleling... So bit curious...
Mishu.
