12V DC supply for running DC motor at 200 rpm.
udayan92
Full Member level 5
Full Member level 5
India
I want to run a DC motor using PIC16F877A and for increasing the current level,I will be using L293 IC.
I have got the code ready...the problem is in arranging the 12V power supply for the IC.Apart from the
12V battery,what are some other ways through which I can provide a 12V DC supply for the IC..?
any clean, stable 12VDC power supply should work, provided it can supply enough current
i assume you are using a different power supply for the motor
