12F675 NEC IR Decoder
xhizt
Newbie level 1
Newbie level 1
Hi, I'm having a hard time decoding NEC protocol. This is my assignment and I'm new to microcontrollers. I'm working with mikroC PRO for PIC and ISIS Proteus.
I made NEC signal with address/inverse/command/inverse and measured it in Proteus, used IRLINK to transfer it to GP3 and nothing works.
I used GPIO.GP1 ON/OFF just to check on oscilloscope what happens and it appears my interrupt misses first pulse.
Any suggestions, comments or different approaches on this problem are welcome
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
// NEC IR DECODER
   _MCLRE_OFF;_PWRTE_OFF;_CP_OFF;_CPD_OFF;_FOSC_INTRCIO;
static unsigned long counter;
static unsigned input_data, bit_count;
static unsigned char address=0,address_inverse=0;
static unsigned char command=0,command_inverse=0;
unsigned char dataready = 0;
unsigned long time;
unsigned int edge = 0;
enum {
        Start,
        Wait,
        Capture
char Current_state = Start;
void interrupt(){
    if(INTCON.T0IF)                                         // check the timer0 over flow interrupt flag
          counter++;
      else if(INTCON.GPIF){                          GPIO.GP1=1;GPIO.GP1=0;
          time = ((counter<<8)+TMR0);                    // time since last interrupt
          counter = 0;
          TMR0 = 0;
        switch (Current_state){
           case Start:
                      if(time >= 8000 && time < 10000) {        //wait 9ms leading pulse
                         bit_count = 0;
                         input_data = 0;
                         Current_state = Wait;
                      break;
           case Wait:
                      if(time >= 4000){              // wait for 4.5ms
                      Current_state = Capture;
                      else{
                      break;
           case Capture:                       //9ms + 4.5ms passed
                      edge++;
                      if (edge == 2){                   //edge  waits for 2 interrupts ( skips rising edge )
                          input_data = input_data<<1;    // shift buffer
                          if(time<=1300){
                          input_data = input_data | 0x0;             // add 0 to received data
                          bit_count++;
                          else{
                            input_data = input_data | 0x1;          // add 1 to received data
                            bit_count++;
                          edge = 0;
                      //complete 32 bit
                      if(bit_count == 32){
                        address         = (input_data>>24)& 0xFF;                        //extract the data from the buffer
                        address_inverse = (input_data>>16)& 0xFF;
                        command         = (input_data>>8) & 0xFF;
                        command_inverse = (input_data)    & 0xFF;
                        input_data=0;                                                       //clear the buffer
                                        if((!(address & address_inverse)) && (!(command & command_inverse)))                // check NEC
                                        dataready = 1;
                                        else
                                        dataready = 0;                 // wrong code
                      break;
            default: Current_state = Start;
      INTCON.GPIF = 0;                       //clear interrupt flag.
INTCON.T0IF = 0;                     // clear the timer0 interrupt flag
void main()
     CMCON = 7;                           //Disable Comparator
     ANSEL = 0;                             //All digital I/O
     TRISIO = 0x8;                          //Configure I/O Pin
     GPIO = 0x00;                          //Set all output to 0
     OPTION_REG = 0x88;                  //pullups are disabled  , timer0 prescale 1:1
     IOC = 0x8;                           //interrupt on change is only to the GPIO3
     INTCON.T0IE = 1;                    // Timer0 overflow interrupt enable
     INTCON.T0IF = 0;                    // clear the timer0 intrrupt flags
     INTCON.GPIE = 1;                    // external interrupt on GP3  is enabled
     INTCON.GPIF = 0;                    // clear the external interrupt flag
     INTCON.PEIE = 1;                    //enable interrupt
     INTCON.GIE = 1;                     //enable global interrupt
     TMR0 = 0;
        while(1){
              if(dataready){
     if(command == 0b01010000){GPIO.GP0 = 1;   }//test
              dataready = 0;
