128X64 Graphical LCD foant size
samic45mit1
Member level 3
indore
I am using 128X64 GLCD (KS0108) with ATMEGA32 Micro controller and I using lib given on link https://en.radzio.dxp.pl/ks0108/ for same. I successfully interface it with atmega32 but when I try to change font size 5X8 to 12X16 (TABLE FOR 12x16 IS ALREADY GIVEN IN HEADER) in below function by changing value of i loop to 12 and (12*charToWrite) but I not gatting any result.
Code C - [expand]
8
9
void GLCD_WriteChar(char charToWrite)
   int i
    charToWrite -= 32;
    for(i = 0; i < 5; i++)
         GLCD_WriteData(GLCD_ReadByteFromROMMemory((char *)((int)font5x8+(5 * charToWrite) + i)));
         GLCD_WriteData(0x00);
So please tell what is wrong.
Can you show us what did you write exactly to use the bigger fonts.
I think something more than this needs to be done, as the fonts you are trying to use bigger than the page size and that will affect this.
This is the change I made in above function
int i
charToWrite -= 32;
for(i = 0; i < 12; i++)
GLCD_WriteData(GLCD_ReadByteFromROMMemory((char *)((int)font12x16+(12 * charToWrite) + i)));
Each 16 pixel column will occupy two bytes, so the code can hardly work.
Hello!
You will need to rearrange your data in 2 rows. On most of the small graphic LCDs, 1 byte writes a column
of 8 pixels. So you need to write the upper part of your character on one 8-pixel band, and the lower part
on the next 8-pixel band.
Nothing complicated, just some index manipulation.
Pascal
