12 volt dc timer relay hook up help
taaaaaapis
Newbie level 2
Hi
i want to hook up my 12v restroom fan in my cabin with a timer so that it goes on 1 hour than off 1 hour around the clock. i've got batteries hook up on solar panels that gives me power
to do the project i got myself
1 12v-24v dc omron timer model h3cr-a+ its base
1 omron 12vdc relay model g2r-1-s +base
hoe do i hook up my batteires with the timer relay and fan, wich pin number do i use.
in attach the specs sheets of my products
thank you
denis
1000 Thanks mister rf
works perfect!
peace
Please note: you need to select for the solid state timer a B2 mode, also time unit selector and time range selector according to the planned time.
In my example I have set mode for minutes, multiplier set on 3 and the cursor on 20, to obtain 1 hour ON, 1 hour OFF cycle.
