Dear all
I am in urgent need to solove the quary in wimax MIMO-OFDM mode.
In this model, after running the program, 1 is to be entered for including the MIMO and O for single input single output system.
How ever my qaury is in both the cases, with same parameter (i.e. channel bandwidth, SNR etc), i am getting the same BER.
Ideally using MIMO-Alamouti configuration, the BER should be reduced.
I want to know how i can achive the lower Bit Error Rate using MIMO configuration in this model only. or which parameter(s) i have to set for comparing the BER performance of MIMO and SISO i.e by entering 0 and 1 in this model.
I have run this model many times and in each configuration i am getting the same bit error rate for MIMO and SISO configuration. i donot know why....
Kindly give me replay as soon as possible.
