1-wire Search ROM routine
Inkwaterman
Member level 1
search rom
Hi !
I have to interface a PIC to a 1-wire bus with 3 devices.
I have just used some 1-wire devices , but I haven't used a 1-wire bus.
Has anybody done a 1-wire Search ROM routine ?
If it's possible , can you post me your source code ?
Tnx
irfanahh
Newbie level 3
rom search
i am making also a interface between Microcontroller MSP430f149 and multilple ibuttons devices through Transport DS2484. search algorithem now i am writing but this is not complet...i am also finding some guy who has some ideas about it...if u got some solution plz inform me also..irfan
    V
Inkwaterman
Member level 1
one wire search rom
Hi !
in my case I had to interface some 1-wire devices with a Microchip PIC, for did it I used a PIC's PIN , without any Transport DS2484.
If you want I can post you my code, it works well .
The only thing that you have to do is to adapt it to your requirements ..
Regards
irfanahh
Newbie level 3
search rom ds1820
Hi..
it will be nice if u send me ur code...i will change it according to my requirement...because basic search algorithum work on the same way..i am waiting ur answer thanks alot irfan
martinisonline
Member level 2
Portugal
ds18s20 search rom
I have a 1-wire Search ROM routine write in CCS. If you are interested, i post it.
stroma
onewire search rom
hi martinisonline,
i'm interested too. can you post you code?
best regards,
stroma
martinisonline
Member level 2
Portugal
routine c one wire
I atached a complete working project i made some time ago. It's about the DS1820 (Digital temperature sensor) that works over a onewire bus.
It includes:
onewire.c driver
ds1820.c driver
main.c file of project.
It will search all devices atached to the bus, and indexes them. If one device is disconnected or connected, it will perform a new search index.
the files have some comments in english and most of them in portuguese. If you have some problem, post it.
stroma
ds18s20 rom code
nice work- very useful for me, thanks a lot
best regards,
stroma
snoopy
Member level 1
ds18b20 search rom
Tnx for code, I tried and compiler could not find LCD driver and header for 1820.
Is it possible to upload this too.
Regards
BOjan
martinisonline
Member level 2
Portugal
ccs one wire routines
The driver for ds1820 is already attached in the previous post. you need to put it in the C:\???????\PICC\Drivers. or define in the options in ccs another directory for the drivers.
The driver for flex_LCD wasn't made by me, but it has usefull coments. it's easy to understand.
khongai
Full Member level 4
ds18s20 search rom microchip
you can find at maxim website
snoopy
Member level 1
www. search-roms .com
Finaly I made, very useful, TNX
Your CODE is working in my test board. But now I have new problems.
I do not have debagger circuit for testing code step by step.
Which variable present temperature ?
Bojan
martinisonline
Member level 2
Portugal
pic one wire search
At main.c file after "lcd_init()":
procurar(); -> search all devices in the bus
convert_temp(); -> send to the bus the code to start a temperature conversion to all devices.
read_temp(dados, i); -> read the value of device 'i' and save it in the variable 'dados'
trata_temperatura(dados); -> Do a math calculation to get the extended resolution (see ds1820 datasheet, pag. 4) and put the value at "inteiro" and "decimal"
the value of temperature is known after the function 'trata_temperatura(dados);"
Value: AA,BB ºC where: AA -> "Inteiro" and BB -> "Decimal"
You need to format the printf like the example at main.c:
printf(lcd_putc,"Int.: %02u,%02u 'C ",inteiro, decimal);
i had 2 sensors. one inside and other outside the room. The Int.: in the lcd is the inside temp. and the Ext.: is the outside temp.
snoopy
Member level 1
1wire search rom
HI
I was successful to read 64 bit ROM adress from my 18S20 and manualy write it to program.
Program detect the sensor, but does`t show correct temperature. LCD alveys show
3,39 C even to worm sensor with fingers.
Any idea where is problem?
Regards Bojan
martinisonline
Member level 2
Portugal
1 wire search rom
probably the problem is the funtion "read_temp(dados, i)". After the funtion "procurar()", the program 'enumerates' the devices (1, 2, 3, ...).
go to the onewire.c driver, at funtion "void FindDevices(void)" delete the \* and *\:
// DESCRIÇAO: Procura novos dispositivos no bus
// INPUT: Nada
// OUTPUT: Nada
int8 m;
if(!ow_reset())
if(First()) // Begins when at least one part found
numROMs = 0;
do
numROMs++;
for (m=0;m<8;m++)
FoundROM[numROMs][m] = ROM[m]; // Identifies ROM no. on device
/* <---DELETE THIS
printf("\r\nEndereco do dispositivo No %u: ",numROMs);
printf("%X%X%X%X%X%X%X%X\n\r",
FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5],
FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2],
FoundROM[numROMs][1],FoundROM[numROMs][0]);
*/ <---DELETE THIS
} while (Next() && (numROMs<10)); // Continues until no additional
// devices found.
// printf(lcd_putc,"\fTotal Disp.: %u",numROMs);
// delay_ms(500);
// putc('\n'); putc('\r');
now you can view in hyperterminal the rom code and the device number (I assume that you are using rs232)
At main.c edit one of the "IFs" with your DS18S20 rom code.
my example:
//edit---------------------|-------------------------------|------------------------------|---...
if(FoundROM[7]==0xe1 && FoundROM[6]==0x00 && FoundROM[5]==0x08 && FoundROM[4]==0x00 && FoundROM[3]==0xc4 && FoundROM[2]==0x8f && FoundROM[1]==0xbb && FoundROM[0]==0x10){
//se o chip do interior corresponde ao ROM //E1000800C48FBB10 <-- Rom code
After this, if you have problems, post your code.
soulraven
Newbie level 6
Campulung Muscel, Romania
1-wire search routine
hello, I tried the code above, just go try to adapt to ds18b20 ..... which have to adjust .... comments are in Spanish and do not understand
abric
Newbie level 1
hello,
i done the "rom search" routine in assembler
contact me at ---abric.jy@libertysurf.fr---
or go to the french site "pic mcu" of "BIGONOF" in application from "abric jean-yves"
lorac_241
Newbie level 1
I'm from Spain and the comments are in Portuguese, not in Spanish ¬¬ Learn languages before talking so bravely.
avh
Newbie level 1
Thanks to martinisonline I made ROM search work for the Rabbit RCW5600W module. Needed tweaked timing and disabling interrupts at critical moments. (used an oscilloscope for debugging :)
PS: I found you really need a 4k7 pull-up, I got inconsistent results with a 10k resistor.
