1-wire DS2450 AD converter problem
lockerman
Member level 1
ds2450
I need to solve the following problem:
I have DS2450 (1-wire AD converter) and want to control it by 3.3V microcontroller. Problem is that DS2450 requires 5V power supply to operate.
Does anybody have any simple idea how to create 5V for DS2450 in 3.3 system without using too many other circuits ? System is powered from battery, so no other external supply more that 3.6V is available.
The solution should be low-power.
ANy help appreciated.
Thanks
Cluricaun
Advanced Member level 2
DS2450
Hi
I plan to build something of the DS2450 myself so I am interested to know more of your plans. For the voltage you can use a step up converter, there are many ones around, so I cannot give some exact advice about a circuit but I have used mc34063 and it was cheap (and worked) but check maxim and motorola and others
Check here:
123.nomad.ee/micros/mc34063a/index.shtml
123.maxim-ic.com/appnotes.cfm/appnote_number/661/ln/en
For DS2450 check parasite powering here:
hxxp://pdfserv.maxim-ic.com/arpdf/AppNotes/app147.pdf
You know what to do with the xx and 123...
Good luck
Kripton2035
Western Europe
totaly out of the subject...
can you tell me why you replace some letters from url's ?
for fun ? to escape CIA ?
when the data is confidential, i understand such practice, but here it's public so.. why ??
lockerman
Member level 1
I have some experience with MC34063. However, this step-up converter is too "hangry" for my application. It's power consumption is too high. I would prefer inductorless design. There are few charge pumps from MAXIM (e.g MAX768, MAX1686, etc ) however the ripple volatge is too high. Any other idea?
Thanks
Lm
Cluricaun
DS2490
Hi
Ok I understand, I havent used them but linear.com/prod/pft.html has alot of efficient step up converters. If I remember correctly they have inductorless ones aswell with low ripple.¨
Check MAX619 and LTC3200 they are inductorless (just 2 examples), havent checked ripple and so on.
Use their parametric search, just choose 3.3v in 5v out, inductorless and so on. I hope this helps you and that Mr France is upset once again...
Good luck
mr_ghz
Full Member level 5
Hi lockerman,
when the ripple of a charge-pump is to high, why not use a charge-pump
and additional an LDO linear voltage-regulator? 2 more components
(the LDO and 1 cap) and you have a correct supply (important for analog
circuits).
Bye
