0.7V ultra low noise supply
vlsi_design2
Junior Member level 2
I want to test an LNA IC. I want to use supply of 0.7V and make it as low noise as possible. I plan to use a 6V lead acid battery and then use a voltage regulator as follows
https://www.ti.com/lit/ds/symlink/tps76201.pdf
Can anybody suggest better ways? The lab power supplies that I have make the noise figure 1dB worse.
