Suggest me a digital project related to logic design
unkn0wn
Junior Member level 3
Can anyone suggest any projects related to logic design..
the project is to be based on 90% digital stuff.. like counters, flipflops, latches, gates, registers, encoders, decoders, multiplexers, demux......
PC interfacing, Microcontrollers, PLDs are not allowed.
Re: Digital Design
If you are new with these projects then you can try making a digital clock...
else you can try implementing any system like electronic lock......
Re: Digital Design
projects other than these too..... due to limitations can't pick them up...
not even the easily found traffic light.....
Re: Digital Design
limitations means what sort of limitations....?
limitations in resources.....?
Re: Digital Design
viterbi coding , u can find code also in google search.
Re: Digital Design
yup... discreete ones..
and nopes, the limitation is that the projects are assigned to other students...
Re: Digital Design
UART module in discrete componets can be tough i hope... it can be implemented easily with programmable logic devices....
Re: Digital Design
U can better design an ALU handling integer data.. It ll have latch , mux etc..
If u r so interested in counters , then design divide by an integer(6 or 9 etc) counter...
Re: Digital Design
How about a capacitance meter. Just need a counter a couple of 7segments and equal amount of 7segment drivers maybe some others elements. Just need to measure the discharging time of the capacitor under observation, this can be done using a counter and dsiplaying the final count on the 7segments. Some setting will need to be done in order to obtain a result equivalent to the value of the capacitance.
Re: Digital Design
think designing an alu for a beginner witll be tough... it will require lot of design and it will be tedious to do with latches,counters....etc....
Re: Digital Design
I dont think for designing integer type ALU , v should need advanced knowledge of digital.. For floating type , its difficult for a newbie..
