Help me design a filter for a PLL with 125 MHz reference freq. and 2GHz output freq.
sastry
Newbie level 5
i have to design a pll with following specifications
i am using simulink
the reference frequency is 125 Mhz
the output frequency is 2.0 Ghz
how do i design the filter for the circuit
and the vco has 2 specifications in pll
the quiescent frequency and input sensitivity
now how can i calculate those.....
i have built the phase detector.how to i build the charge pump and the frequency divider.
pll specifications
u can use a digitsl counter for frequency divider as the division ratio is 16. (2x2x2x2).
pll specifications
it's such a big system
hard to say
Re: pll specifications
Have you looked at the Matlab central web page? There is an analog modeling seminar that goes into this in details. I've mentioned this a couple of times before, so if you search for my postings here, you'll find a link.
Dave
www.keystoneradio.com
i am using simulink
Try the 'PLL Tutorial' on this website: **broken link removed**
For charge pump. there are many papers for mention this circuit.
For Divider, it is the critical part in the PLL design.
First of all, you can need to design the prescaler with dual modulus or single modulus.
For dual modulus prescaler, you can adopt 3/4 or 4/5. I usually use SCL or TSPC type. SCL means souce couple logic. TSPC means: true single phase clock.
After prescaler, the frequency is low, you can use asynchonus divider to control the dual modulus divider to achieve your divider number. The asynchous divider is CMOS type that it use many FFs and gates to implement it.
Yibin.
pll specifications
read book wrote Razavi about the PLL
