how WiMAX changes its modulation technique
shah_jiii
wimax modulation
need help on the ability of WiMAX to change its modulation technique as distance from BS increases
wimax modulation scheme
WiMAX system adjust the signal modulation and coding scheme on the basis of Signal to Noise ratio (SINR) condition of the radio link. When the radio link quality is high the highest modulation sceme and light coding is used giving the system more capacity. During a signal fade or long signal path the wiMAX system can shift to a lower order modulation sceme with heavier coding to maintain the connection quality and link stability.
So we have SNR = 22 dB the modulation is 64 QAM
SNR= 16 dB modulation 16 QAM
SNR= 9 dB modulation QPSK and
SNR = 6 dB modulation BPSK
-Sidd
wimax modulation techniques
sir can u give some more detail or link or some article related to modulation techniques
wimax modulation schemes
The IEEE 802.16 standard speaks about this also
you can find various papers in this forum itself.......
Try to search for Adaptive Modulation for the conceptual understanding.
-Sidd
wimax modulations
One question: How does the base station mesaure the SNR..
just by measuring its received power?
wimax snr
Yes, for uplink SNR the Base station calculates SNR by received power while for downlink the subscriber station calculates and sends the requirement of its particular suitable burst profile....
Typical calculation can be --------
If Pr is received power in dBm then.
SNR(dB) = Pr(dBm) – No(dBm)
Where No (dBm) is the noise power in dBm, Assume, the carrier bandwidth is B, the receiver noise figure is F, the spectral efficiency is rb/B and the coding gain Gc
Then the SNR for coded modulation with data rate rb can be obtained by
SNR (dB)= 10 log[(Pr/No)x(rb/B)] -Gc
Where No (dBm) = -174(dBm) + 10 log B + F (dB)
Where Gc is normally considered as 5dB.
-Sidd
modulation schemes used in wimax
thank you ricksidd, could you give us any book or website containing informations about the calculation of SNR of WiMax
Many thanx
modulation wimax
can you give me matlab code for how to change code rate and modulation scheme?
thanks
snr wimax
Actually WiMax uses the technique of OFDM in which we have the Orthogonal frequencies to modulate oure data. Thats changes the technique of modulation in WiMAx
modulation in wimax
bit loading decrease 1 per 3dB
modulation for wimax
is there any way to do a project on WiMAX but also in hardware related? n if posible, how much would it cost?
regards.
wimax cinr modulation
Many thanx
h**p://www.esnips.com/doc/22406aa7-a327-4bbf-b3a4-f8e08fb71f0a/John.Wiley..Sons.WiMAX-Technology.for.Broadband.Wireless.Access.2007
modulation scheme for wimax
As far as I know the wimax std species mandatory modulation techniques as Qpsk(1/2,3/4) 16 QAM ,64qQAM ..
BS station species the modulation we are using which is the same for the whole frame.
suppose if u have a frame with 30 symbol duration the modulation scheme remains the same for all the symbols
wimax+modulation
Hi
If you have a frame with 30 symbols duration i think that the modulation scheme remains the same for all the symbols because logically and if we examine the OSI Model , frame will take delimitor in second layer (link)whereas the modulation will be in physical layer.
Added after 46 seconds:
Hi
Added after 1 hours 47 minutes:
Hi
Re: wimax+modulation
can any one give me a matlab code of different modulation techniques of wimax
