What is the advantage of flash memory over SRAM or DRAM?
mohsin_kiet
Junior Member level 3
flash memories
what is a major advanage of a flash memory over a SRAM or DRAM????
flash memories
Well, the biggest adv is that it is non-volatile. Both SRAM and DRAM lose data when power is removed. DRAM loses it in every read operation! So thats where flash is helpfull. Disadv is that it is slower
Re: flash memories
flash memory basically has non volatile memory.
you can store your programs that create variables and constants in ram .
ram can be many types ...sram,dram,sdram,ddram..
now-a-days nand gate memory is in use which is better than flash memory
flash memories
BOTH VOLATILE MEMORY DRAM SLOW THAN SRAM
