How to interface LCD using 4 bit STN mode
Look here:
best regards
EG7502 is graphic LCD
Hi C-Man,
Thanks for the answer but the link is for character LCD, EG7502 is a graphical LCD
RGDS
Hi weeyndha,
look at a LCD controller datasheet (I gave you the link for a b/w 320*240 Pixel controller). There is also described how the interfacing to the LCD is made.
How do you want to drive the LCD? Directly by a micro? This is possible but will take a lot of power. If you need grayscale you have to implement a frame-rate modulation. This is complicated to do it right (or you will get a lot of moiree on the screen).
Here the link: **broken link removed**
Bye
Choosing LCD controller
Hi mr_ghz,
Now the question is how to choose LCD controller? Is it only based on pixel size? Thanks for your help.
Rgds
Hi weeyndha,
They differ also in pixel RAM (internal or external) and in the uP interface. I have already used a S1D13705 (the datasheet I gave you). This one has an internal pixel-RAM and can be connected to nearly every uP. You can use it with 1/4 VGA sized displays (320*240 Pixels) b/w or color.
Bye
Hey,
anybody can give me a link for epson EG7502 datasheet,or just its pinout, i have the module, but, its hard to find its datasheet on nets
thx
BTW, can you give me datasheet of LCD LFH8P4032B of ALPS.
Thanks
