Achut Giree
Junior Member level 1
1 second clock pulse
can pulse per hour be generated using multivibrator practically ?
Long Time Delays
In the 556 timer the timing is a function of the charging rate of the external capacitor. For long time delays, expensive capacitors with extremely low leakage are required. The practicality of the components involved limits the time between pulses to around twenty minutes.
To achieve longer time periods, both halves may be connected in tandem with a “divide-by” network in between. The first timer section operates in an oscillatory mode with a period of 1/fO. This signal is then applied to a “divide-by-N” network to give an output with the period of N/fO. This can then be used to trigger the second half of the 556. The total time is now a function of N and fO.
; generating 1 second pulse every 240 minutes with PICAXE-08
low 1 ; set output 1 low
loop:
high 1 ; set output 1 high
wait 1 ; wait 1 second
For w1=1 to 240 ; 60 = 1 hour, 120 = 2 hours, 180 = 3 hours and 240 = 4 hours ..
wait 60 ; wait 1 minute
Next w1
Goto loop
End
